Export method
  • duncanwong
    • Jan 2008
    • 10
    Export method
    Now zabbix have web interface to export template etc.
    Anyone try it in command line?
    As I want to schedulely export ALL templates in linux cronjob
    Thz.
  • troffasky
    • Jul 2008
    • 639
    Are you intending to do this as a way of backing up your Zabbix? It's not going to work, as certain things [eg Screens, Maps] can't be exported to XML. If you want to back up Zabbix I suggest you dump the SQL database.
