Monitoring VPNS's
  • bytesize
    • Aug 2005
    • 71
    Monitoring VPNS's
    Hi guys,
    I have several remote agents running on servers in satellite offices, and I would like to be able to monitor whether there is VPN connectivity between the two agents on private network addresses adn then create a trigger when it goes down.
    Is this possible?
    Thanks!
    John
  • Rudolf
    • Dec 2004
    • 90
    Is your VPN server running on Linux? I run a Linux gateway with VPN connections. I would do something like that:
    Write a small script, maybe:
    ifconfig | grep 10.100.100.210 | wc -l
    The IP is your VPN p-t-p IP for the remote server. The output of this line is 0 or 1. 0 means there is no connection to the server, 1 means connection is established. Set up an UserParameter that runs this script, and you get the result (0 or 1).
    • mconigliaro
      • Jun 2005
      • 116
      a simple ping to the remote device would probably be fine.
      • Lovespider
        • Sep 2004
        • 99
        I'm trying to find the correct OID to ask Cisco VPN router to tell me if the tunnel is up via SNMP. If I found something I'll post here.
        • jpawlowski
          • May 2005
          • 45
          that would be great but my research did not respond in great results... i looked into the MIBfile of Cisco and could not find anything releated to VPN tunnels...
