How can I show my CPU usage in percentage?
  • NomenNescio
    • Jan 2009
    • 70
    So for example, if my cpu's max speed is 2.4 Gigahertz, how can I show in % how much I'm using?
  • dotneft
    • Nov 2008
    • 699
    system.cpu.util[<cpu> <,type><,mode>]
    Processor load in percents
    cpu - CPU number (default is all CPUs)
    type - one of idle, nice, user (default), system
    mode - one of avg1 (default),avg5 (average within 5 minutes), avg15
    Example: system.cpu.util[0,user ,avg5]
    Zabbix Manual 105 page
    • NomenNescio
      • Jan 2009
      • 70
      Thanks but isn't there a better way than that? That doesn't method doesn't work on windows. Is there a better way? Also, is there a way to get the opposite of idle time, because, Solaris does not support system time but if I get the opposite of idle time ( 100.0 - idle time) I get to see how much cpu is being used. Is such a thing possible?
      • ataylo13
        • Feb 2007
        • 122
        system.cpu.util[,,avg1] = % utilization across all cpus. works on linux and windows
        Version : 1.8.8
        Current Configuration 1 Master and 3 Child Nodes
        • NomenNescio
          • Jan 2009
          • 70
          So these values mean how much % is being used?
          • ataylo13
            • Feb 2007
            • 122
            Yes.But I would log into the box and verify that the numbers match.
            Version : 1.8.8
            • NomenNescio
              • Jan 2009
              • 70
              Ah okay, thank you. :-)
              • bbrendon
                • Sep 2005
                • 873
                You can't find total CPU utilization as a percentage.
                ...This shows user CPU usage and not total. The only way to get the total is by using a custom parameter.
                Unofficial Zabbix Expert
                Blog, Corporate Site
                • jroberson
                  • May 2008
                  • 124
                  This is what I use as a key:
                   perf_counter[\Processor(_Total)\% Processor Time]
                  That seems to work for most of my Windows systems. You can find the whole list of these if you run "perfmon" from that host and then you can just find the counter (right-click on graph and "add coutner") in Perfmon. Then open the properties for it and copy-paste it into the key field after "perf_counter" You can monitor a lot more things in Windows this way.
                  • NomenNescio
                    • Jan 2009
                    • 70
                    Okay thank you
                    • nima0102
                      • May 2010
                      • 106
                      Hi
                      I have found your reply after search on forum.
                      I need to "cpu utilization" for all CPUs in percent. but with this solution can I get cpu utilization??
                      Thanks in advance
                      • Lozzano
                        • Jan 2011
                        • 12
                        Hey,
                        I would like a key that shows both user and system load in %'s combined, how would I do that?
                        - Lozz
