How to notify Debian/Ubuntu updates ?
  • batosai
    • Dec 2008
    • 10
    Is there a way to be notified when Debian/Ubuntu packages are available for updates ? Nagios has a check_apt plugin to do it. Is there a way to do this with Zabbix ?
    Regards
  • sbockelman
    • Oct 2008
    • 16
    Debian/Ubuntu Show updates
    Install the "apt-show-versions" package from apt.
    Add Item:
    system.run[apt-show-versions | grep upgradeable | wc -l]
    Add trigger that checks if that number is greater than 0.
    • troffasky
      • Jul 2008
      • 639
      Add Item:
      Excellent. I like that one a lot. This will also work in scenarios where you're using net-snmp to monitor a Debian host, as it can be added to snmpd.conf where it'll then be visible under .1.3.6.1.4.1.2021.8.
      This is great if you've got lots of Debian boxes to maintain, as with a template you can monitor the status of every host's package management system at once.
      • batosai
        • Dec 2008
        • 10
        Thanks, but system.run[] isn't available with 1.4.2 agent, which is the version packaged in Debian/Ubuntu. Is there a zabbix repository somewhere, or should I try the unstable package ?
        • troffasky
          • Jul 2008
          • 639
          I think you should try checking the value of EnableRemoteCommands in zabbix_agentd.conf first :-) If you're not happy with the security implications of that, you could implement it as a UserParameter instead.
          • bbrendon
            • Sep 2005
            • 873
            I'm 99% sure 1.4.x has system.run support once its enabled in agent conf file.
            Unofficial Zabbix Expert
            Blog, Corporate Site
