See that a link switch is functioning properly?
  • fluque
    • Sep 2007
    • 9
    I'm trying to monitor several of the main links to backbone switch, to see if there are any problems with any links.
    The variables that I am monitoring are IfAdminStatus and IfOperStatus, but I'm not sure that is correct, and that triguers should use to see if a link has been dropped?
    Thanks very much,
    Regards,
    Francisca
  • troffasky
    • Jul 2008
    • 639
    ifAdminStatus is not the one you want, it'll change when the port is disabled or enabled by the switch administrator. ifOperStatus is going to be more useful to you, basically it tells you if the link is up or down.
    • fluque
      • Sep 2007
      • 9
      Redundant links.
      Thanks.
      In the case of redundant links Spaning tree, this variable is correct, or is there another more appropriate MIB variable?
      • troffasky
        • Jul 2008
        • 639
        It Depends. Some switches offer a lot more information than others via SNMP, eg HP Procurve 2626 has ~19000 items available via SNMP, vs ~6000 items on a Linksys SFE2000P, and both of these are 24 port switches. I suggest you snmpwalk your intended target and see if it supports what data you're after.
        • troffasky
          • Jul 2008
          • 639
          The following OIDs may be of interest:
          BRIDGE-MIB::dot1dStpPortState
          BRIDGE-MIB::dot1dStpPortEnable
          Eg from a Procurve 2650 with STP enabled [note that you won't be able to see these OIDs until STP is enabled]:
          BRIDGE-MIB::dot1dStpPortState.32 = INTEGER: disabled(1)
          BRIDGE-MIB::dot1dStpPortState.33 = INTEGER: forwarding(5)
          From BRIDGE-MIB:
          dot1dStpPortState OBJECT-TYPE
              SYNTAX      INTEGER {
                              disabled(1),
                              blocking(2),
                              listening(3),
                              learning(4),
                              forwarding(5),
                              broken(6)
              MAX-ACCESS  read-only
              STATUS      current
              DESCRIPTION
                  "The port's current state, as defined by application of
                  the Spanning Tree Protocol.  This state controls what
                  action a port takes on reception of a frame.  If the
                  bridge has detected a port that is malfunctioning, it
                  will place that port into the broken(6) state.  For
                  ports that are disabled (see dot1dStpPortEnable), this
                  object will have a value of disabled(1)."
              REFERENCE
                  "IEEE 802.1D-1998: clause 8.5.5.2"
              ::= { dot1dStpPortEntry 3 }
