Simple ping check with triger on 3 match
  • gregober
    • Jan 2009
    I am trying to figure out how to triger an alert when ping fails more than three time for a given host…
    I would like to know if this will be ok or not?
    {host :icmpping. count( 3,0 ) }=3
    My simple goal is to trigger the alert if the answer is positive more than three times in a row. Positive beeing "I can not ping host" = 0.
    If there is more simple or straightforward way of doing that, I am ok to learn ;-)
  • ashuji
    • Dec 2008
    • 35
    Hi
    Please try the below formula:
    {host :icmpping.count(#3,1)}<1
    This formula says, turn ON trigger if count of '1' (success) is less than 3 in last 3 attempts.
    Regards
    Ashwani Jain
    • gregober
      • Jan 2009
      The answer that you gave me could not be applied.
      I had a closer look at the suggested format, and I think what I want ist that:
      {host:icmpping.avg(#3)}=0
      This means that the average of the last three "ping check" = 0
      I think this is what I want…*
      • ashuji
        • Dec 2008
        • 35
        Both are OK
        I believe both are OK.
