defining multiple severity levels in one trigger
  • Filter
    I have a trigger for low disk space on an agent. It is set to Average. Is it possible to create an expression that sets severity to a LOW for let's say free disk space < 5G and HIGH for < 1G?
    Thanks!
    I have only been able to accomplish this using 2 triggers.
    Version : 1.8.8
    Current Configuration 1 Master and 3 Child Nodes
      That's cumbersome. I wish there was a way in the expression logic to force a new severity.
        Easiest way I know is to create two triggers and make one dependent on another, with higher severity
        Zbx 2.0.4 on Debian and MYSQL5 on Ubuntu Server 64bit 8.04,
        200+ Win Agents, 50+ Linux Agents, 150+ Network Devices
          Oh good tip. Wouldn't have thought to do a dependency at first. Should be able to template that logic of course so that is OK.
            I still see a need for this..
            I've opened a Request
              Same situation (lot of similar triggers). If it's clear to me, such feature will be realised in 1.8.5
                Unfortunately developers see this code/DB model change as a nuisance that doesn't justify the improvement.
                  I've tried to reopen the issue,
                  as I see it important not only for our monitoring scenarios but for other large installations.
                  Announcement
                  No announcement yet.
