Add items dynamically
  • sarathyme
    • Mar 2009
    • 58
    i want add items to zabbix dynamically from a java code, please let me if it can be done.
    These are the ways i am thinking,
    1) Direct update to database
    2) Import items from code
    please suggest me a better way to do this.
    (By the way, do not think the requirement is crazy, adding items dynamically we really that functionality. we have a code that captures new clients info, as and when it finds a client it would wants to add to zabbix...........)
    Vijay
  • underguiz
    • Jun 2009
    I did it using a combination of Visual Basic script and curl to post a new item to items.php while I was using zabbix 1.4, but now that i've upgraded to 1.8 it doesn't work anymore because of the sessionid in the url that the frontend uses now.
    I am thinking in a way to insert a new row in the items table, not sure if it will work..
    • alixen
      • Apr 2006
      • 474
      If you are using Zabbix 1.8, you should look at new API:
      http://www.zabbix.com/documentation/...i/objects/item
      Regards,
      Alixen
      http://www.alixen.fr/zabbix.html
      • underguiz
        • Jun 2009
        care to show me some examples?
        • alixen
          • Apr 2006
          • 474
          I'd love to do it, but I am still discovering 1.8 new features.
          API is on my checklist but I haven't started to play with it yet.
          Regards,
          Alixen
          • underguiz
            • Jun 2009
            ok, thanks anyway.
            • richlv
              • Oct 2005
              • 3112
              you could try looking at zabcon for some inspiration
              http://www.zabbix.com/wiki/?do=search&id=zabcon
              • underguiz
                • Jun 2009
                Ok thanks, i'll take a look.
