Value / Custom_Interval
  • xFlux
    • Mar 2007
    How could I do the following:
    Custom Value divided by Custom Interval.
    I basically have a script that pulls a value from flat file, and resets the value timer each time I pull the value. I am tracking the last pull from the custom counter.......So basically I need to make a custom Delta.
    eg. VALUE=10 / TIME(ms)=30000
    I know this can be accomplished at my script level, but I would much rather keep an absolute value and have Zabbix divide the custom interval, so I can later graph this.
  • td3201
    • Nov 2008
    • 25
    Isn't that the multiplier setting? So to divide by 3000, you would put this in the multiplier: 0.00033
    Hopefully I am on the right track. Pretty new to this.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Td3201 is absolutely right. The multiplier can be used to divide as well. Just calculate 1/30000 and use it as a multiplier.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
