Monitoring HDD temperature
  • UUVtQD
    • Mar 2009
    • 11
    Hi All!
    I'm trying to monitor HDD temperature on my server.
    In /etc/zabbix/zabbix_agentd.conf I add line
    UserParameter=HDDTempSDA,hddtemp /dev/sda |cut -f3 -d":" |cut -f1 -d"°"|tr -d ' \011\015\032'
    restart the zabbix-agent, try to test it and got this:
    [root@alfa ~]# zabbix_agentd -t HDDTempSDA
    HDDTempSDA                                    [t|25]
    This means the UserParameter HDDTempSDA is working, isn't it?
    So, I tried to add it to "Items":
    Description:                     SDA HDD Temp
    Type:                              Zabbix Agent
    Key:                               HDDTempSDA
    Type of information:          Numeric (float)
    Units:                              C
    Use multiplier:                  Do not Use
    Update interval (in sec):     60
    Flexible intervals (sec):	No flexible intervals
    Keep history (in days):       90
    Keep trends (in days):        365
    Status:                            Active
    Store value:                     As is
    Applications:                    OS
    Group:                            Linux servers
    And press "Save" button.
    But after pressing "Mass update" at the bottom of "Items" page the status of HDDTempSDA is displayed as "Not supported".
    Why? What am I doing wrong?
    Thanks in advance!
    P.S. Both servers use CentOS 5.2
  • UUVtQD
    • Mar 2009
    • 11
    Ok,
    i'm found error.
    Log-file zabbix-agentd contains the following:
    /dev/sda: open: Permission denied
    How can I fix this?
    Thanks in advance.
    • nelsonab
      • Sep 2006
      • 1233
      Looks like a permissions error. Try running hddtemp as a normal user (not root) and see if you get a permissions error. You might need to provide the full path, on my system it's /usr/sbin/hddtemp
      Two ways to fix. One you can wrap sudo around this, and the other is to setuid root for hddtemp if it is not already.
      RHCE, author of zbxapi
      • UUVtQD
        • Mar 2009
        • 11
        Thanks for help!
        "sudo" does not work - require "real tty" but the idea of "setuid" - is worked!
        Thanks again for your help!
