Templates import problem
  • John007
    • Mar 2009
    Hallo.
    I use Zabbix 1.6.2.
    I made some host templates which have relations with one another. Here is sample situation:
    TemplateCommon
    ...\ TemplateStation
    ...\ TemplateServer \ TemplateSQLServer
    .......................................\ TemplateAnotherServer
    I would like to export these hierarchy and repeatedly use on the another sites I administrate. But there is first problem in export. There is no possibility to export host with its own items, triggers ... only. Host in export adopt all inherited items, triggers ....
    I edited exported XML (clean inherited items ...) and check that links to templates are OK.
    When I import such XML I loosed relations between templates.
    I have to import them separately in order "parent then child". If I use such annoying procedure, relations are OK.
    Do I something in wrong way? Or is it feature?
    Thank you for answer or hint.
    Jan
