zabbix_agentd giving wrong results for hard disk
  • bisana
    • Jul 2005
    • 87
    Hi all
    I had tried my luck in zabbix mailing list , I had posted this problem to the mailing list , I thought of posting it to the forum also
    I am need guidance , I switched to “zabix_agentd” monitoring since SNMP was not giving me the correct parameter for CPU usage
    Here now Zabbix_agents is working fine for some parameters, but for checking the hard disk space it give me all wrong answers monitoring through zabbix_agentd ,
    I was not getting correct result for Free disk space on “/” “/home” , it always shows 1.33 MB for both the values , the key which I had given is “diskfree[/home]” , diskfree[/], the other parameter which i monitor I am getting the desired results
    Please guide me
    Joseph John
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Give us output of 'df' or 'df -k'.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • bisana
      • Jul 2005
      • 87
      df -h and key details added
      Hi Alexei
      Thanks for the reply , I am sending the , view detail
      A>> The View details in Zabbix shows
      Total disk space on / 09 Aug 10:00:00 0 B - Graph
      Total disk space on /boot 09 Aug 10:15:10 0 B - Graph
      Total disk space on /opt1 09 Aug 10:00:01 0 B - Graph
      Total swap space 09 Aug 10:00:02 2.00 GB - Graph
      Used disk space on / 09 Aug 10:15:01 0 B - Graph
      Used disk space on /tmp 09 Aug 10:15:01 0 B - Graph
      WEB (HTTP) server is running 09 Aug 10:15:03 0
      B>> df -h gives
      df -h
      Filesystem Size Used Avail Use% Mounted on
      /dev/md0 38G 36G 1.3G 97% /
      /dev/md2 62M 23M 35M 39% /boot
      /dev/md3 72G 36G 33G 52% /opt1
      none 2.0G 0 1.9G 0% /dev/shm
      C>> And host conf detail
      For Disk total
      key is "disktotal[/boot]" for total disk space on /boot
      "disktotal[/opt1]" for total disk space on /opt1
      "disktotal[/]" for total disk space on /
      For Used Disk Space
      key is
      "diskused[/]" for diskused on /
      • James Wells
        • Jun 2005
        • 664
        Greetings,
        Right off the bat, it appears that you have the multiplier set incorrectly. My guess is that you have the multiplier set to 1000, if so, change it to 100.
        Also note that since /home is actually part of the / filesystem, that you will be unable to obtain usage information on home, but it will instead be part of the information you recieve for /
        Unofficial Zabbix Developer
        • bisana
          • Jul 2005
          • 87
          It was the problem of Multiplier
          Hi James , Alexi
          I was able to resolve the problem
          I kept the multiplier set to 1000
          my humble suggestion
          1>Some of the default template for host.unix the multiplier is set to 0 , so when some is making a copy of it he gets answer 0 ( for eg disktotal[/tmp] , disktotal[/]
          2>Some documentation regarding the multiplier , and why it is used should be given in the manual / help file
          THANKS to Alexi and James
          Joseph John
