Announcement
No announcement yet.
monitoring ipvsadm connections
  • Filter
    I wrote UserScript and template about monitoring ipvsadm connection
    to use this
    download ipvsadm.py.txt and place it as /etc/zabbix/ipvsadm.py as executable.
    download zabbix_lb_connection.xml and import.
    in agent host, you have to add below to /etc/zabbx/zabbix_agentd.conf and restart agent
    UserParameter=ipvsadm.activeconn[*],/etc/zabbix/ipvsadm.py active $1 $2 $3
    UserParameter=ipvsadm.inactconn[*],/etc/zabbix/ipvsadm.py inactive $1 $2 $3
    my ipvs setting is below
    $ sudo ipvsadm -L -n
    IP Virtual Server version 1.2.1 (size=4096)
    Prot LocalAddress:Port Scheduler Flags
    -> RemoteAddress:Port Forward Weight ActiveConn InActConn
    TCP 172.18.0.12:80 lc
    -> 172.17.0.21:80 Masq 1 17 165
    -> 172.17.0.22:80 Masq 1 17 203
    in webui, copy items from template(Template_LB_connection) to ipvs host and change item key like below
    ipvsadm.activeconn[tcp,172.18.0.12:80,172.17.0.21:80]
    ipvsadm.inactconn[tcp,172.18.0.12:80,172.17.0.21:80]
    This is work, but there is problem about operation.
    when i add real server, i have to add or copy items and change key each time.
    Does anyone know other easy way?
    Has someone use this?
    i've no data in the graphs.
