Anatomy of a trigger....
  • cbidwell
    • Aug 2006
    • 127
    Is there any documentation of the different parameters of a trigger?
    i.e.
    {Template_Linux:proc.num[]. min( 900 ) }>350
    {Template_Linux:net.tcp.service[pop]. last( 0 ) }=0
    The proc.num is obvious...but there appears to be several different options for the next settings.
    min,diff, last, etc. are there a list of what all of these are and the syntax on how to use them?
  • terry
    • Mar 2009
    • 21
    Check out the zabbix manual. All of the parameters, macros, etc are explained in there. I am not saying it's the holy grail of documentation either. It needs a lot of work but at least start there.
    http://www.zabbix.com/documentation.php
