Monitoring D'Link DGS1248-T
  • philippn
    • Dec 2007
    I'm trying to monitor one of my D'Link DGS1248-T switches.
    Receiving the data via SNMP works.
    As I like to monitor the bandwith of our backbone, I added some Items (e.g. Output of Port 46):
    				<item type="1" key="o46" value_type="3">
    					<description>Out 46</description>
    					<delay>10</delay>
    					<history>90</history>
    					<trends>365</trends>
    					<status>0</status>
    					<units>B</units>
    					<multiplier>1</multiplier>
    					<delta>2</delta>
    					<formula>8</formula>
    					<lastlogsize>0</lastlogsize>
    					<snmp_community>public</snmp_community>
    					<snmp_oid>.1.3.6.1.2.1.2.2.1.16.46</snmp_oid>
    					<snmp_port>161</snmp_port>
    				</item>
    But there is something wrong because I have a current bandwith of 1.39 GBit/s, what (unfortunatelly) not possible.
    I think I use a wrong multiplier..but what's the correct value?
    With best regards from Germany,
    Philipp
  • troffasky
    • Jul 2008
    • 634
    Is it consistently wrong? Try clearing the history if you've been changing the multipliers.
    • philippn
      • Dec 2007
      Thx for that tip, but it doesn't work.
      Any other ideas?
      • Cray
        • Mar 2009
        • 72
        Typically, a switch port from which you want to get the current bandwidth is supposed to be configured like this (configuration -> items -> targeted item )
        - Type of information : numeric (float)
        - Units : B
        - Use multiplier : Do not use
        - Store value : Delta (speed per second)
        If your switch is not an obscure and non-standard SNMP device, it should work;
        Btw, have tried to look at the template's switchs configuration ? it might help
        • rihassani
          • Jul 2013
          D'Link DGS1248-T Template
          Do You Have D'Link DGS1248-T template Please!!!
          Best regards
