Problem graphs after upgrade 1.6.2->1.6.4
  • fege
    • Dec 2008
    • 34
    I have a screen compose by few graphs, if i press on one ot this zabbix go to the page of graph but it is empty. And if i go directly on tab graph and chose one it is the same, the page remain empty.
    But if i go on latest data and press graph i can show the graph!
    any suggestion?
    thanks
  • Cray
    • Mar 2009
    • 72
    The graph you are talking about in the "latest data", is an auto-generated simple graph (if I'm right), and is not the same as the graph you can create in the Configuration -> Graphs section.
    Have you tried to clear your browser's cache & history ?
    • fege
      • Dec 2008
      • 34
      ok, i try to clear cache and history as soon as possible
      But i try both mozzilla and ie and the result is the same
      • Cray
        • Mar 2009
        • 72
        I have upgraded from 1.6.2 to 1.6.3, and from 1.6.3 to 1.6.4 without any problems. Although it's not exactly what you did, there should be no problems, as soon as you upgrade the zabbix binaries and the frontend files.
        Can you post 2 or 3 screenshots to see what's exactly the problem ?
