1.6.4 zabbix server is running = no
  • veroli
    • Mar 2009
    Hi all,
    well i decided to have a go at compiling zabbix from source on a fresh ubuntu install, relatively painless and it all seemed to come up.
    However my zabbix server is running status is set to no and i cant seem to get it to start.
    also on the status of zabbix page i get the following error
    fsockopen() [<a href='function.fsockopen'>function.fsockopen</a>]: unable to connect to 192.168.1.100:10051 (Connection refused)[/home/zabbix/public_html/include/config.inc.php:774]
    feel i am very close so any help very much appreciated
    regards
    Dan
  • t2y
    • Feb 2009
    • 60
    Hi Dan,
    Did you look at as follows page?
    Can you find an answer which you want?
    http://www.zabbix.com/wiki/doku.php?...:ubuntuinstall
    • veroli
      • Mar 2009
      thanks
      that was the guide i followed but ended up with the server not runnin, still not sure why
      thanks
      dan
      • veroli
        • Mar 2009
        ok i fixed it.
        a bit silly of me but all i had to do was put the password in the server config file and it all came to life. Maybe i should have checked the log file a bit earlier. Still live and learn and its working now.
        • bbrendon
          • Sep 2005
          • 873
          Wholly smokes!!!!
          The Ubuntu install guides in the wiki were ruined! acK!
          That guide is not very good!
          Unofficial Zabbix Expert
          Blog, Corporate Site
          • veroli
            • Mar 2009
            thought it was quite good really, it was my own error really apart from that it all went pretty well
            • snowcrash
              • Aug 2009
              zabbix_server = NO = solved
              Originally posted by bbrendon
              Wholly smokes!!!!
              I do agree with this statement. I've read a lot of technical documentation and it
              left a lot to desired for clarity and accuracy. I'm still very new to the intriguing world of linux and it would have been nice if the authors had written the wiki with the aim of simplicity. Nevertheless, it was a helpful article and is far more clear to me than the manual has been.
              As for my problem, it was as simple as entering the password in the zabbix_server.conf file.
