Stop and upgrade zabbix?
  • NomenNescio
    • Jan 2009
    • 70
    Is there an easy way to stop and upgrade zabbix?
    How do I stop the zabbix process?
    I currently do it with the kill command but I don't think that's the right way.
    How do I install the newer version?
    Whenever I run "make install" the binary files in the /usr/local/sbin don't get replaced and are not outputted anywhere??
    I'm trying to upgrade from 1.6.3 to 1.6.4
  • tchjts1
    • May 2008
    • 1605
    Depends on what OS you are on. I think Linux in general you use these stop commands -
    sudo /etc/init.d/zabbix-server stop
    sudo /etc/init.d/zabbix-agent stop
    sudo /etc/init.d/mysql stop
    sudo /etc/init.d/apache2 stop
    When I run the make command, I do it differently and run:
    make
    then I run
    sudo make install
    And of course, they will go to wherever you define in your prefix statement during the compile. In my case it is --prefix=/usr so they then go into /usr/sbin for me.
    • NomenNescio
      • Jan 2009
      • 70
      I don't have these files...
      Where can I get these scripts?
      Edit:
      These scripts are in misc/init.d/ but I'm using Ubuntu I can't find a ubuntu folder there, which one should I use?
      Edit:
      Ah, figured it out. I used the red-hat script. I also didn't add the prefix during config that's why it didn't work for some reason. It seems that if you don't explicitly add the prefix the files in the default installation folder won't be overwritten.
      • tchjts1
        • May 2008
        • 1605
        Yeah... I use this command to move the scripts into the correct place...
        From the /home/zabbix/zabbix-1.6.4/ dir or wherever you unzipped the source to:
        sudo cp misc/init.d/debian/zabbix-server /etc/init.d
        sudo cp misc/init.d/debian/zabbix-agent /etc/init.d
        And then also chmod them and set them to run at startup...
        sudo chmod 755 /etc/init.d/zabbix-server
        sudo update-rc.d zabbix-server defaults
        sudo chmod 755 /etc/init.d/zabbix-agent
        sudo update-rc.d zabbix-agent defaults
        PS - I have a good set of install instructions for Ubuntu/MySql... just drop me a note if you'd like them.
