Zabbix & maps
  • jenifer1402
    • Apr 2009
    • 21
    Zabbix & maps
    in the figure maps the line connect between the two hosts is always red. Yet in the configuration I set the color green for the type on.
    any ideas why?
  • jenifer1402
    • Apr 2009
    • 21
    any ideas why?
    no idea?
    • rue
      • May 2006
      • 43
      no idea?
      Without some more info, this is difficult to debug... . How did you setup the map and to what kind of trigger did you connect the connection between the hosts with?
      cheers
      Rü
      • jenifer1402
        • Apr 2009
        • 21
        Zabbix & maps
        [QUOTE=rue;45196]Without some more info, this is difficult to debug... . How did you setup the map and to what kind of trigger did you connect the connection between the hosts with?
        it must define a connection type? I have not defined, then how should I define it? may be that is my problem
        • rue
          • May 2006
          • 43
          When adding a connection between two zabbix hosts, you have to define a "Link status indicator" (usually a trigger).
          The status of the trigger defines the status of the connection, so: If trigger is in ON ("problem state"), you get a red line, green if it is OFF... .
          cheers
          Rü
          • jenifer1402
            • Apr 2009
            • 21
            maps & zabbix
            cheers
            Rü
            thanks, is good I understood all, and I solved my problem, but I have another problem:
            In the configuration of maps I had another problem.
            I want to set a background image but I can not because in the background image that is 'no image'
            any idea why!!!!
            • jroberson
              • May 2008
              • 124
              Go to Configuration -> General
              Choose Images from the drop-down list on the right.
              Click "Greate Image" button.
              Be sure to have "Background" selected and then name and upload your background.
              • jenifer1402
                • Apr 2009
                • 21
                maps & zabbix
                I solved my problem, really thanks
