Created a graph at template hoping that it will be available for all the hosts which are attached to the TEMPLATE.
It worked only with a issue -- When I go to view the graph the GRAPH NAME is repetaed but I don't the HOST NAME. Tried using {HOSTNAME}<Graph name> but it does not work (meaning show {HOSTNAME} as it is)
Any body has tried the same
THANKS for help
THANKS for help
