help installing zabbix
  • davet47
    • Apr 2009
    I'm trying to install zabbix on fedora 10, and when I enter the following command:
    ./configure --enable-server --with-mysql --with-net-snmp --with-libcurl
    I get an error that says:
    checking for getopt_long... yes
    checking for mysql_config... /usr/bin/mysql_config
    checking for main in -lmysqlclient ... no
    configure: error: Not found mysqlclient library
    I have the mysql client library installed but it's not finding it. I'm new to linux, and trying to learn so any help would be great.
    Thanks!
  • caarts
    • Aug 2008
    • 37
    Try adding the path during configure
    --with-mysql=/usr/lib/mysql
    Installing mysql-devel might do the trick too
    • davet47
      • Apr 2009
      I was missing the mysql-devel package. Installed that and it worked beautifully. Thanks for the tip!
