Distributed monitoring
  • jenifer1402
    • Apr 2009
    • 21
    hello,
    I would like to know if is it possible to have one or many Zabbix remote servers (behind firewall), which checks their remote hosts and to report all to the central server.
    thanks
  • rue
    • May 2006
    • 43
    Originally posted by jenifer1402
    hello,
    thanks
    Yes, you could use zabbix proxies (easiest) or some more zabbix servers for that... . Just refer to the manual (16.1 "Use of Proxies" ).
    cheers
    Rü
    • jenifer1402
      • Apr 2009
      • 21
      cheers
      Rü
      You don't understand me ,I will re-explain :
      I have install multiple servers Zabbix(x), each server monitors client machines. and I have a Central Zabbix server (Y) . I want to collect all the data monitoring server (X) in the central server (Y). can I do this? if yes so how?
      • rue
        • May 2006
        • 43
        Yes, you can collect data from decentralized server(s) to a central server (see documentation 1.7...), you can also transform existing "stand alone" servers to report to one central server... . If that's not what you mean, I don't get it... . Sorry.
        cheers
        Rü
