hi,
whenever I run typeperf on this server I'm installing zabbix on I'm getting a error, example:
What does this mean? Isn't t the computer able to connect with itself? I tried it with running the command prompt as administrator but that didn't help.
Edit:
I've found this on the interweb,
This arises a question, does the correct functioning of typeperf depend on a service? If so, which one? Because the server I'm using has quite a few services disabled.
C:\zabbix\typeperf -qx Error: Unable to connect to specified machine or machine is off line.
Edit:
