How to delete a specific record from DB
  • bobrivers
    • Feb 2007
    • 115
    We are monitoring a windows perfcounter that accumulates it's value since the last time that the server was restarted. Actually it's the server print spooler.
    Ok, no problem with that. We created an item in zabbix (perf_counter[\Print Queue(xpto)\Total Jobs Printed]) and we are storing it as a Delta (simple change).
    For some reason, after rhe restart of the server in which zabbix is hosted, zabbix miscalculated the value. In general, the value is arounf 50 and after the restart it registered a value of 1000.
    In fact, I don't know if it's miscalculated or not, but this value is messing my graphs...
    Is it possible to delete it from zabbix? I was thinking about delete it directly from the DB.
    Could someone point to me the tables that I need to manipulate?
    TIA,
    Bob
  • jroberson
    • May 2008
    • 124
    Do you mean to "clear history" of the item? There is a button for that on every item and at the bottom of the list so you can check and clear multiple at once.
    • bobrivers
      • Feb 2007
      • 115
      Thanks, but no, I don't want to clear al the history. Just te record that seems to be wrong...
      • bbrendon
        • Sep 2005
        • 873
        If you know the value of the record, you can go into the db and do something like (untested)
        delete from history_uint where itemid = ### and max_value > 100
        ...or is it trends_uint?
        Anyway, I do this sometimes if the values get crazy.
        Unofficial Zabbix Expert
        Blog, Corporate Site
