Trigger - Compare against String
  • jcesario
    • Apr 2009
    • 65
    I would like to create a trigger where I compare the .last of an Item against a string.
    Something like
    {My_Item} != "Foo"
    or
    {My_Item} == "Foo"
    Do I have to map against int values to do this? I havent been able to find a condition that accepts a string for N
  • MarkusL
    • Nov 2008
    • 41
    Hi!
    I´m not sure, if this is waht you are looking for:
    ({template:key[].regexp(MyString)}#0)
    This trigger says: when MyString is found in the item-value -> Trigger on.
    I use this f.e. for backup-exec
    ({backupexec:backupdaily[check].regexp(failed)}#0)
    --> Trigger goes on, when item gets a value "failed".
    Kind regards,
    Markus.
