the prerequisite for Zabbix
  • jenifer1402
    • Apr 2009
    • 21
    they are the prerequisite for Zabbix , CPU,Memory....?
    size of memory, cpu...
    thanks for any reply
  • harmonica
    • Jan 2009
    • 251
    http://www.zabbix.com/downloads/ZABB...ual%20v1.6.pdf
    • lamont
      • Nov 2007
      • 89
      16-32GB RAM, dual quad-core procs, 6x15k SAS drives, RAID controller with 512MB of cache will be able to monitor 200+ hosts with lots of detail (items) on the hosts, when properly tuned.
      • Kerrygeek
        • Dec 2008
        • 115
        The specs in the manual seem a little low, or maybe I'm just not used to pushing mine quite that hard. I just set mine up in February so I don't have a lot of experience with it yet but it's doing a fine job for us. I have a Xeon 2.5 gig with 4 gigs of RAM running CentOS 5.2 on RAID5 with SAS drives. My load average varies from .35 to about 1.5 but usually stays between .7 and 1.0.
        My dashboard says this:
        Number of hosts (monitored/not monitored/templates) 129 83 / 1 / 45
        Number of items (monitored/disabled/not supported) 3528 1468 / 2050 / 10
        Number of triggers (enabled/disabled)[true/unknown/false] 480 479 / 1 [0 / 202 / 277]
        Number of users (online) 11 3
        Required server performance, new values per second 22.5017
        When I look at Admin/queues I don't ever see anything queueing up so I assume I still have plenty of room to grow. I asked about capacity early on and Alexei said not to worry until I had something like 150 values/second so it should still have plenty of head room.
        Hope that helps!
        Kerry
        • lamont
          • Nov 2007
          • 89
          After thinking about this more, i'd pay most attention to:
          1. Hardware RAID controller with battery backed RAM cache (my 512MB RAID caches make me happy, single SATA controllers with no RAID controller make me sad -- i'm not sure if 256MB on the RAID controller is sufficient, but I'd take that over no RAID or software RAID).
          2. CPU. The mysql database is actually CPU hungry. I'd want dual quad-core procs next. 4 cores (dual-dual or single-quad) will work, but my current scalability limit seems to be CPU-limited on mysql.
          3. Memory. The more memory the larger you can make the innodb buffer pool size and the more data will be cached in memory which makes a difference in responsiveness for looking at historical data. I'd do at least 16GB, but I'm upgrading some of my servers to 32GB now.
          4. Faster drives and more of them. If you've got good RAID hardware this actually seems to be second to CPU limits, but clearly 15k SAS drives will be better than 7.2k SATA drives. I'd at least recommend 10k SAS drives. You want more drives for the extra spindles and I/O rather than for space. You aren't going to be too likely to get a zabbix database larger than 100-200GB (i don't think any of mine exceed 100GB, but i prune my history tables fairly aggressively).
          So, somewhere between:
          256MB RAID controller
          4 CPU cores
          16GB RAM
          2 3.5" 10k SAS drives in RAID10
          and:
          512MB RAID controller
          8 CPU cores
          32-64GB RAM
          8 2.5" 15k SAS drives in RAID10
          • jroberson
            • May 2008
            • 124
            I envy those server specs! In reality it all comes down to what you will be monitoring. My system works decent and I don't have any complaints with how Zabbix is working with what I have given it. Before I tell you my specs, here is my Zabbix:
            Number of hosts (monitored/not monitored/templates) 95 62 / 5 / 28
            Number of items (monitored/disabled/not supported) 3137 2085 / 991 / 61
            Number of triggers (enabled/disabled)[true/unknown/false] 784 775 / 9 [15 / 79 / 681]
            Number of users (online) 4 1
            Required server performance, new values per second 58.2275
            Here is my Zabbix "server" specs:
            CPU = Pentium 4 (hyperthreaded) @ 3ghz
            RAM = 768MB
            HDD = 1x 40GB @ 7200rpm (IDE)
            As you can see, I just pulled that "server" out of the pool of desktops (older desktops at that). I admit that the screens and historical graph updates are a little sluggish but all the data is there. My load(15) stays around 1.5-2.0 (while in the frontend it goes to 2.0-3.5)
            Disclaimer: This is really my "test" server that I setup to prove to my coworkers that Zabbix is worth implementing. As it turns out, it works pretty well even on that "low" end of hardware. If you are looking for a test case, you don't need to go all out on the "server". I admit, though, that when I'm ever allowed to fully implement it I'm going for some real server hardware, if I can get the $$.
            • bbrendon
              • Sep 2005
              • 873
              RAM = 768MB
              Wow. Very bold "Values Per Second" for such hardware!! Linux is amazing.
              Unofficial Zabbix Expert
              Blog, Corporate Site
              • bbrendon
                • Sep 2005
                • 873
                4 CPU cores
                16GB RAM
                and:
                8 CPU cores
                32-64GB RAM
                what the heck do you think they are monitoring? Either of those is enough hardware to monitor thousands of servers!
                • alfiere
                  • May 2008
                  • 51
                  I miss something..
                  My hw is a
                  2 CPU 4 core Nehalem E5520 @ 2.27GHz
                  16 GB RAM
                  2x450 SAS 15 k RAID 1
                  Centos 5.3 x86_64 well tuned
                  Number of hosts (monitored/not monitored/templates) 79 61 / 7 / 11
                  Number of items (monitored/disabled/not supported) 4669 3796 / 541 / 332
                  Number of triggers (enabled/disabled)[true/unknown/false] 1522 1135 / 387 [2 / 1 / 1132]
                  Required server performance, new values per second 135.3472 -
                  [root@~]# cat /proc/loadavg
                  2.27 2.20 2.34 1/327 14434
                  with
                  27552 mysql 15 0 502m 43m 6712 S 17.7 0.3 10203:58 mysqld
                  mysql never under 15%
                  (mysql 5.1.34 innodb)
                  Again, zabbix queue shows:
                  Items 5 seconds 10 seconds 30 seconds
                  ZABBIX agent 327 1221 114
                  Any suggestions?
                  Regards,
                  Alf
