Maps with multiple connections and multiple link indicators
  • jamied66
    • Sep 2008
    • 37
    I have a network map (like most everyone), and a few questions.
    I'm monitoring each port's admin and oper status as seperate triggers. So if I add both of those triggers as link status indicators do they both have to be true for the link to turn colors, or will either one cause it (is it an "and" or an "and/or" situation?)
    Also, with devices that have multiple connections (i.e. eth0 and eth1 on the same switch as a bonded pair), will the line change colors if either interface goes down, or is it conceivable for the "up" connection to effectively cover up the "down" connection?
    Thanks for any thoughts!
