Support of SNMP parameters was not compiled in
  • vijaya.r85
    • Apr 2009
    • 20
    I have installed zabbix-1.6.4 in solaris based on the http://jacksonstrong.blogspot.com/20...n-solaris.html
    Everything went smooth. when I configure any snmp enabled device I am getting an error like "Not supported" in status and "Support of SNMP parameters was not compiled in" in Error column of items.
    When I restart the server I found in log as...
    4469:20090515:142536 server #1 started [Poller. SNMP: NO]
    4470:20090515:142536 server #2 started [Poller. SNMP: NO]
    4471:20090515:142536 server #3 started [Poller. SNMP: NO]
    4472:20090515:142536 server #4 started [Poller. SNMP: NO]
    4473:20090515:142536 server #5 started [Poller. SNMP: NO]
    4474:20090515:142536 server #6 started [Trapper]
    4475:20090515:142536 server #7 started [Trapper]
    4476:20090515:142536 server #8 started [Trapper]
    4477:20090515:142536 server #9 started [Trapper]
    4478:20090515:142536 server #10 started [Trapper]
    4479:20090515:142536 server #11 started [ICMP pinger]
    4480:20090515:142536 server #12 started [Alerter]
    4481:20090515:142536 server #13 started [Housekeeper]
    4481:20090515:142536 Executing housekeeper
    Please help me in fixing this..
    Thanks in advance,
    Vijaya. R
  • MrKen
    • Oct 2008
    • 652
    There is currently an active thread about this.
    MrKen
    • vijaya.r85
      • Apr 2009
      • 20
      Timeout while connecting to [IP]
      Thanks for your swift response Mr.Ken.
      I reconfigured zabbix-1.6.4 now. I have added one host and in Items i configured snmpv2agent. but I found things like Availability - Not Available and Error - Timeout while connecting to [IP] in hosts. I went through the forums but dint find solution yet. Please help me on this.
      Thanks in advance,
      Vijaya. R
      • MrKen
        • Oct 2008
        • 652
        Does that mean you now see this in your zabbix_server.log:
        4469:20090515:142536 server #1 started [Poller. SNMP: YES]
        4470:20090515:142536 server #2 started [Poller. SNMP: YES]
        4471:20090515:142536 server #3 started [Poller. SNMP: YES]
        4472:20090515:142536 server #4 started [Poller. SNMP: YES]
        4473:20090515:142536 server #5 started [Poller. SNMP: YES]
        Next, is snmp enabled on the host to be monitored? If it is a Cisco device you would need something like this:
        snmp-server community public RO
        Next, is the snmp community name correct? If you are using a different community name you need to change the community name on the Template --> Items screen.
        Finally, is there a firewall between Zabbix and your host?
        MrKen
        • jagannath
          • Mar 2008
          • 10
          As we are getting response through command /snmpwalk -v 2c -c
          I dont think there is any firewall inbetween host and Zabbix server.
          Regards,
          Jagannath
          • MrKen
            • Oct 2008
            • 652
            Now I am confused!! jagannath you start one thread, then vijaya.r85 starts another thread about exactly the same problem. Then jagannath moves across to this thread. What is going on here?
            Q1. Are jagannath and vijaya.r85 working together on one problem? Or are there two separate people with two unrelated problems?
            Q2. Is zabbix configured with netsnmp? Are you sure? How do you know for sure?
            Please note that being able to snmpwalk only means that 'the server' has snmp installed, it does not mean that zabbix is configured with snmp.
            • jagannath
              • Mar 2008
              • 10
              We both are working on the same issue.
              We have compiled
              ./configure --prefix=/export/home/zabbix/server --enable-server --enable-agent --with-mysql --with-net-snmp=/opt/coolstack/bin/net-snmp-config --with-libcurl=/opt/curl/bin/curl-config
              in ps -eaf | snmp
              root 621 1 0 May 14 ? 0:00 /usr/lib/snmp/snmpdx -y -c /etc/snmp/conf
              root 655 1 0 May 14 ? 0:00 /usr/lib/dmi/snmpXdmid -s nms
              root 616 1 0 May 14 ? 0:37 /usr/sfw/sbin/snmpd
              root 13183 1 0 May 15 ? 0:07 /usr/sfw/sbin/snmptrapd -C -c /etc/snmptrapd.conf /var/log/net-snmptrapd.log
              root 13202 1 0 May 15 ? 0:07 /usr/sfw/sbin/snmptrapd -C -c /etc/snmptrapd.conf
              root 6291 4958 0 11:44:23 pts/3 0:00 grep snmp
              Now the eror refletc while restarting the zabbix serve
              6193:20090518:113858 SNMP monitoring: YES
              6193:20090518:113858 WEB monitoring: NO
              6193:20090518:113858 Jabber notifications: NO
              6193:20090518:113858 ODBC: NO
              6193:20090518:113858 IPv6 support: NO
              pls suggest if we are wrong.
              Thanks,
              Jagannath
              • MrKen
                • Oct 2008
                • 652
                OK that looks to be good.
                Have you corrected the Timeout problem that you mentioned in the other thread?
                Is the item configured with the correct snmp community name?
                Can you give me the following information from the Item config:
                SNMP OID
                SNMP port
                Key
                Type of information
                Units
                Also, can you post any error messages that you are now receiving.
                • vijaya.r85
                  • Apr 2009
                  • 20
                  Web monitoring No and timeout while connecting
                  Mrken, Thanks a lot for the detailed info. I have checked all those you have mentioned and there is no problem in those. I am getting the web monitoring No in my server log and also for host with snmp, timeout while connecting.
                  In forums it has mentioned that web monitoring = No, mite be due to curl installation problem. But I have installed curl and curl -v also works.
                  I don't know where it is getting struck... please help me on this.
                  Awaiting for your response
                  Thanks,
                  Vijaya
                  • MrKen
                    • Oct 2008
                    • 652
                    Please note that I am not an employee of Zabbix, nor do I provide a free Zabbix Helpdesk.
                    You guys would be more helpful if you answered the questions asked, provided the information requested and stopped changing the topic from 'Support of snmp parameters not compiled in', to 'Timeout while connecting', to 'Web monitoring', to ....
                    I really don't know what the topic is anymore. Have any of your problems been resolved? I don't know because you don't answer the questions.
                    That said - On this link http://jacksonjstrong.blogspot.com/2...aris_2022.html
                    he says: The 1.1 version of Coolstack didn't have the new enough version of curl for zabbix.
                    # cd /var/tmp
                    # gunzip curl-7.16.2.tar.gz
                    # tar xf curl-7.16.2
                    # cd curl-7.16.2
                    # ./configure --prefix=/opt/curl --without-ssl
                    # make
                    # make install
                    But I don't know because I don't use Solaris, and also you say "curl -v" works but you don't post the output!
                    In my initial install I had to install curl and curl-devel, so maybe you need to manually install that as well.
                    Good luck
                    • jagannath
                      • Mar 2008
                      • 10
                      Thanks for your response
                      Pls find the item config option
                      Type -- SNMPv2
                      SNMP Community --public123
                      SNMP OID--- 1.3.6.1.4.1.9.2.1.57.0
                      SNMP Port--- 161
                      Key ---system.cpu.switches
                      Type of information--- Numeric(unsigned)
                      Units -- %
                      • MrKen
                        • Oct 2008
                        • 652
                        Your item configuration is wrong!
                        You should be able to snmpwalk the OID and the key and get the same result.
                        [root@zabbix ]# snmpwalk -v2c -c public xxx.xxx.xx.xx 1.3.6.1.4.1.9.2.1.57.0
                        OLD-CISCO-SYSTEM-MIB::lsystem.57.0 = INTEGER: 16
                        [root@zabbix ]# snmpwalk -v2c -c public xxx.xxx.xx.xx system.cpu.switches
                        2009-05-18 15:30:44 system.cpu.switches: Unknown Object Identifier (Sub-id not found: system -> cpu)
                        Now if we change the key to 'lsystem.57.0' look what we get:
                        [root@zabbix ]# snmpwalk -v2c -c public xxx.xxx.xx.xx lsystem.57.0
                        Another example:
                        snmpwalk this OID - .1.3.6.1.2.1.1.3.0
                        now snmpwalk this - sysUpTimeInstance
                        Hopefully that will solve one of your problems.
                        MrKen
                        • jagannath
                          • Mar 2008
                          • 10
                          Thanks for your continious support on this issue.
                          root@zabbix # snmpwalk -v 2c -c public123 10.0.0.1 1.3.6.1.4.1.9.2.1.57.0
                          SNMPv2-SMI::enterprises.9.2.1.57.0 = INTEGER: 8
                          root@zabbix # snmpwalk -v 2c -c public123 10.0.0.1 system.cpu.switches
                          root@zabbix # snmpwalk -v 2c -c public123 10.0.0.1 lsystem.57.0
                          lsystem.57.0: Unknown Object Identifier (Sub-id not found: (top) -> lsystem)
                          root@zabbix # snmpwalk -v 2c -c public123 10.0.0.1 1.3.6.1.2.1.1.3.0
                          DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (1041263184) 120 days, 12:23:51.84
                          root@zabbix # snmpwalk -v 2c -c public123 10.0.0.1 sysUpTimeInstance
                          DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (1041267008) 120 days, 12:24:30.08
                          Do i need to make any change on the above syntax
                          Regards,
                          Jagannath
                          • MrKen
                            • Oct 2008
                            • 652
                            Have another look at what I did, then have a look at what you did.
                            You don't have the OLD-CISCO-SYSTEM-MIB installed, so you get a different result.
                            From You
                            The 'key' here is 'enterprises.9.2.1.57.0'
                            Try this: snmpwalk -v 2c -c public123 10.0.0.1 enterprises.9.2.1.57.0
                            See how easy it is.
                            • jagannath
                              • Mar 2008
                              • 10
                              #15
                              I would like to thank ful to you for your contnious support.
                              Secondly i apologize for delaying my reply to you.
                              infact we have deleted the DB and recreated again due to certain issue.
                              now our server is up and running fne but i am not able to moinitor the snmp
                              part.
                              I am getting response from console thru ths command
                              But while configring thru web interface its not working.
                              The error still intact.
                              Switch_cpu - 10.0.0.1 161 - Monitored Not available Timeout while connecting to [10.0.0.1:161]
                              Regards,
                              Jagannath
