I am using zabbix 1.6.2 and trying to test some of the perfmon counters. After defining the Item it works fine but after a while (maybe 15mins or more) the zabbix status for these items switches to "Not supported". i can change them to 'monitored' and they will work for another 15mins or so before switching back to not supported.
I have checked the CPU and Memory Utilization on my Zabbix server they seem to be Normal and i am using Zabbix windows agent 1.6.4
Any work around to Fix this issue.
Regards
Praveen
Regards
Praveen
