Problem with IMPI setup. ipmitool works, but server have no infromation.
  • bogdar
    • Jan 2009
    • 33
    Please, help me configure IMPI monitoring.
    I test IMPI using ipmitool and it works, but I find no clear configuration instructions in zabbix manual.
    infra:~$ id
    uid=104(zabbix) gid=107(zabbix) groups=107(zabbix)
    infra:~$ ipmitool -I lanplus -H i35.....com -U USERID -a sdr list full
    Password:
    Fan 1 Tach | 10275 RPM | ok
    Fan 2 Tach | 8850 RPM | ok
    Fan 3 Tach | 9300 RPM | ok
    Fan 4 Tach | 8850 RPM | ok
    Fan 5 Tach | 9150 RPM | ok
    Fan 6 Tach | 7950 RPM | ok
    Fan 7 Tach | 9375 RPM | ok
    Fan 8 Tach | 8100 RPM | ok
    Fan 9 Tach | 8625 RPM | ok
    Fan 10 Tach | 6000 RPM | ok
    Fan 11 Tach | 8325 RPM | ok
    Fan 12 Tach | 6450 RPM | ok
    Planar 3.3V | 3.27 Volts | ok
    Planar 5V | 5.10 Volts | ok
    Planar 12V | 12.21 Volts | ok
    Planar VBAT | 3.02 Volts | ok
    Ambient Temp | 28 degrees C | ok
    AVG Power | 170 Watts | ok
    CPU 1 Temp | disabled | ns
    CPU 2 Temp | disabled | ns
    SEL Fullness | 12 messages | ok
    CPU 1 PECI tics | -57 unspecified | ok
    CPU 2 PECI tics | -53 unspecified | ok
    Server statup log.
    22511:20090515:190124 ZABBIX Server stopped. ZABBIX 1.6.4.
    10308:20090515:190159 Starting zabbix_server. ZABBIX 1.6.4.
    10308:20090515:190159 **** Enabled features ****
    10308:20090515:190159 SNMP monitoring: YES
    10308:20090515:190159 WEB monitoring: YES
    10308:20090515:190159 Jabber notifications: YES
    10308:20090515:190159 ODBC: NO
    10308:20090515:190159 IPv6 support: YES
    10308:20090515:190159 **************************
    10318:20090515:190159 server #6 started [Trapper]
    10319:20090515:190159 server #7 started [Trapper]
    10321:20090515:190159 server #8 started [Trapper]
    10323:20090515:190159 server #9 started [Trapper]
    10324:20090515:190159 server #10 started [Trapper]
    10327:20090515:190159 server #11 started [ICMP pinger]
    10329:20090515:190159 server #12 started [Alerter]
    10330:20090515:190159 server #13 started [Housekeeper]
    10330:20090515:190159 Executing housekeeper
    10333:20090515:190159 server #14 started [Timer]
    10335:20090515:190159 server #16 started [Node watcher. Node ID:0]
    10336:20090515:190159 server #17 started [HTTP Poller]
    10339:20090515:190159 server #20 started [IPMI Poller]
    10340:20090515:190159 server #21 started [IPMI Poller]
    10338:20090515:190159 server #19 started [Escalator]
    10351:20090515:190159 server #23 started [IPMI Poller]
    10352:20090515:190159 server #24 started [IPMI Poller]
    10354:20090515:190200 server #25 started [IPMI Poller]
    10356:20090515:190200 server #26 started [IPMI Poller]
    10357:20090515:190200 server #27 started [IPMI Poller]
    10359:20090515:190200 server #28 started [IPMI Poller]
    10308:20090515:190200 server #0 started [Watchdog]
    10308:20090515:190200 In main_watchdog_loop()
    10350:20090515:190200 server #22 started [IPMI Poller]
    10360:20090515:190200 server #29 started [IPMI Poller]
    10314:20090515:190200 server #2 started [Poller. SNMP:YES]
    10313:20090515:190200 server #1 started [Poller. SNMP:YES]
    10317:20090515:190200 server #5 started [Poller. SNMP:YES]
    10337:20090515:190200 server #18 started [Discoverer. SNMP:YES]
    10316:20090515:190200 server #4 started [Poller. SNMP:YES]
    10315:20090515:190200 server #3 started [Poller. SNMP:YES]
    10334:20090515:190200 server #15 started [Poller for unreachable hosts. SNMP:YES]
    Libs:
    infra:~$ ldd /usr/sbin/zabbix_server
    linux-gate.so.1 => (0xb7f7c000)
    libOpenIPMI.so.0 => /usr/lib/libOpenIPMI.so.0 (0xb7ea7000)
    libOpenIPMIposix.so.0 => /usr/lib/libOpenIPMIposix.so.0 (0xb7ea2000)
    libiksemel.so.3 => /usr/lib/libiksemel.so.3 (0xb7e96000)
    libcurl-gnutls.so.4 => /usr/lib/libcurl-gnutls.so.4 (0xb7e5d000)
    libnetsnmp.so.15 => /usr/lib/libnetsnmp.so.15 (0xb7dac000)
    libmysqlclient.so.15 => /usr/lib/libmysqlclient.so.15 (0xb7bc3000)
    libm.so.6 => /lib/i686/cmov/libm.so.6 (0xb7b9d000)
    libresolv.so.2 => /lib/i686/cmov/libresolv.so.2 (0xb7b89000)
    libc.so.6 => /lib/i686/cmov/libc.so.6 (0xb7a2d000)
    libOpenIPMIutils.so.0 => /usr/lib/libOpenIPMIutils.so.0 (0xb7a26000)
    libncurses.so.5 => /lib/libncurses.so.5 (0xb79f4000)
    libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0xb7957000)
    libidn.so.11 => /usr/lib/libidn.so.11 (0xb7926000)
    liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0xb7918000)
    libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2 (0xb78d5000)
    librt.so.1 => /lib/i686/cmov/librt.so.1 (0xb78cc000)
    libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2 (0xb78a2000)
    libz.so.1 => /usr/lib/libz.so.1 (0xb788d000)
    libcrypto.so.0.9.8 => /usr/lib/i686/cmov/libcrypto.so.0.9.8 (0xb7739000)
    libpthread.so.0 => /lib/i686/cmov/libpthread.so.0 (0xb7720000)
    libcrypt.so.1 => /lib/i686/cmov/libcrypt.so.1 (0xb76ee000)
    libnsl.so.1 => /lib/i686/cmov/libnsl.so.1 (0xb76d5000)
    /lib/ld-linux.so.2 (0xb7f7d000)
    libdl.so.2 => /lib/i686/cmov/libdl.so.2 (0xb76d1000)
    libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0xb76c0000)
    libgpg-error.so.0 => /usr/lib/libgpg-error.so.0 (0xb76bc000)
    libgcrypt.so.11 => /usr/lib/libgcrypt.so.11 (0xb7654000)
    libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0xb763d000)
    libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0xb75a9000)
    libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0xb7584000)
    libcom_err.so.2 => /lib/libcom_err.so.2 (0xb7581000)
    libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0xb7579000)
    libkeyutils.so.1 => /lib/libkeyutils.so.1 (0xb7576000)
    Host and ites settings:
  • ngit
    • Nov 2011
    Your configuration looks fine.
    Have you enabled StartIPMIPollers in zabbix_server.conf file?
    The default value is 0, which means that IPMI polling is disabled. Set ti to a positive value and it should work.
    • Jason
      • Nov 2007
      • 431
      The Key should be Fan_1_Tach
