Has anyone here set up a trigger to read temperatures from a Papouch TME Ethernet sensor?
It has SNMP and I get some results from $snmpwalk -v 1 -c public <IP>
I also found in a manual:
MIB Table
Temperature as number
Object ID: 1.3.6.1.4.1.18248.1.1.1
GET address: 1.3.6.1.4.1.18248.1.1.1.0
Description: The measured temperature value in degrees Celsius as an integer – the measured value multiplied by ten. (For example, 56.9 °C is expressed as 569.)
Not really sure where to go from there...
Thank you
MIB Table
Thank you
