Status of host group
  • fmtaylor2
    • May 2006
    • 66
    I need to be able to tell the the number or percentage of hosts that are "up" in a particular host group. I have tried a number of things, but can't seem to figure out a working system..
    Any Ideas??
  • kiki_arch
    • Aug 2008
    • 17
    Have you try to use the It Service ? You parameter your group and in this group you put the host with the trigger Hoststatus. I think it can be a way...
