Firing a standalone script
  • nmattox
    • May 2009
    I'm a Zabbix newbie. What I want to do is (seemingly) very simple: Execute a shell script. The script is located on the Zabbix host, in the ExternalScripts directory. The type is "External check", and the key form is: <scriptname:sh[], with nothing in the square brackets.
    It's status is "active", however it's not being executed.
    What did I do wrong?
    Thanks.
  • Calimero
    • Nov 2006
    • 481
    Are permissions fine (including all path components) ?
    How do you now it isn't executed ? What if inside the script you try "date >> /tmp/mylog" ?
    • nmattox
      • May 2009
      Thank you for the suggestions. Permissions did turn out to be an issue on one of the files being written to. The script is working fine now. Thanks again.
