Memory
  • sbarnett
    • Mar 2009
    • 35
    Memory
    I am a newbie with Zabbix and am having a hard time figuring out these triggers. I want to be able to monitor memory space, I want it to trigger it if it is under 200MB of free memory on the server. I have the trigger set as is
    {Template_Windows:vm.memory.size[free].last(0)}<200000
    Is this not correct?
  • troffasky
    • Jul 2008
    • 639
    Yes, it is not correct. That will trigger at 200k.
    • sbarnett
      • Mar 2009
      • 35
      So {Template_Windows:vm.memory.size[free].last(0)}<2000000
      would be 200MB. What does the .last(0) represent?
      • hipikll
        • Dec 2008
        • 12
        last(0) means:
        value of last measuring.
        • sbarnett
          • Mar 2009
          • 35
          Ok change my setting and still is not triggering it. If I look at latest data I can see that the free memory is around 100MB and I see no warning on the Dashboard and it triggers no alert. Anyone know what I am doing wrong?
          • hipikll
            • Dec 2008
            • 12
            Look on items value - on Last Values page and then you can see, if it is correctly measured. If it is correctly measured, then check trigger.
            Can you see your memory value in zabbix?
            And, do you have template linked to HOST?
            • troffasky
              • Jul 2008
              • 639
              would be 200MB.
              No, it wouldn't. 2000000 is two million, so the trigger would be on less than two million bytes free at the last check.
              Make life easier for yourself and use:
              {Template_Windows:vm.memory.size[free].last(0)}<200M
              • sbarnett
                • Mar 2009
                • 35
                The 200M did the trick did not know I could go that route. Thanks a to all. well since I am on a roll what is the difference Zabbix agent and Zabbix agent (active).
                • sbarnett
                  • Mar 2009
                  • 35
                  One more thing how can I get the notification to show me how low the memory is example =
                  Problem on FMSRVR Lack of free memory on server FMSRVR: PROBLEM
                  Memory usage: total:1321.51 Mb - used: 1106.00 Mb (84%) - free: 215.51 Mb (16%)
                  or something to this extent.
                  • NathanX
                    • May 2020
                    All those IT professionals who would like to learn something from here can have a look at this site and we hope that you people would be able to learn much more now. You need to go for www.iuemag.com/u19/ed/5-benefits-of-choosing-offshore-development-center-in-2019 as it was of a main source for help for me.
