monitor hosts only in selected time
  • rexcze
    • May 2009
    is there a possibility to monitor some hosts in selected time? I monitor some user machines and I know, they are switched on only from 8 - 16, but after this time zabbix tells me, that they are unreachable and it considers it as problem.
    Thanks for help
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    This functionality will be supported by Zabbix 1.8. Currently you may consider creating of triggers with time() function in order make triggers work only within certain period of time.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
