Hi Folks,
Any help on this is greatly appreciated. The values I'm getting from zabbix_agentd do not match those that are reported by the operating system.
From zabbix:
# /usr/local/sbin/zabbix_get -s sh-b8.XXXXXXXXXXX -p 10050 -k'vfs.fs.size[/home4,free]'
11878643712
# /usr/local/sbin/zabbix_get -s sh-b8.XXXXXXXXXXX -p 10050 -k'vfs.fs.size[/home4,pfree]'
8.347343
From the O/S:
# df /home4
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/da3s1c 138860928 127260306 491748 100% /home4
Naturally you can imagine this is a bit of a problem. We supposedly have 8% left on that partition but we actually have 0%.
Some host info:
# uname -a
FreeBSD sh-b8.XXXXXXXXXXX 6.1-RELEASE FreeBSD 6.1-RELEASE #0: Sun May 7 04:42:56 UTC 2006 [email protected]:/usr/obj/usr/src/sys/SMP i386
# pkg_info | grep zabbix
zabbix-agent-1.6,2 Application and network monitoring solution
If there's anything else I can provide that might help please let me know. I'm thoroughly confused by this - it has to be something wrong with zabbix_agentd.
Thank you,
Landon
From zabbix:
11878643712
8.347343
From the O/S:
# df /home4
Some host info:
# uname -a
Thank you,
Landon
