configure: error: Not found NET-SNMP library with zabbix 1.6.4
  • fatiha
    • Nov 2007
    • 78
    Here's my config :
    zabbix 1.6.4
    $ net-snmp-config --libs
    -L/usr/local/lib -lnetsnmp -lm
    I have tried anything but I still have that error :
    $ ./configure --enable-server --with-mysql --with-net-snmp --with-libcurl
    checking for net-snmp-config... /usr/local/bin/net-snmp-config
    checking for main in -lnetsnmp ... no
    Thanks,
    Fatiha
  • xs-
    • Dec 2007
    • 393
    search the forums
    --with-net-snmp=/path/to/net-snmp-config
    and/or have net-snmp-config in the $PATH
    and/or make sure the libraries are in the LD_LIBRARY_PATH (or its path in /etc/ld.so.conf)
    and/or make sure that you have the headerfiles in a normal location (if you have a package based OS, this should be the case since you have net-snmp-config already available)
    • fatiha
      • Nov 2007
      • 78
      Thank you xs- I will check those things.
      Fatiha.
      • fredc
        • May 2009
        Hi Fatiha,
        please install net-snmp-devel and it'll work.
        best regards,
        Fred
        • fatiha
          • Nov 2007
          • 78
          Thank you for your answer.
          I will inform you if it works.
          • sayginozan
            • Apr 2011
            Hi
            For Debian (also Ubuntu), You should install "libsnmp-dev".
            Best Regards
            Saygin
