Ping host from a zabbix agent
  • vinny
    • Jan 2008
    • 145
    I searched through the forum and the doc but so far I have not found an answer.
    Is it possible to ping a server within a Zabbix agent ?
    What I want is :
    Zabbix server -> server A with zbx agent, check if ping working to server B
    thx,
    vinny
    Zabbix 1.8.3, 1200+ Hosts, 40 000+ Items...zabbix's everywhere
  • sergio.cricca
    • Mar 2008
    • 43
    I think you should create a script that pings server B and returns 0 if it's OK or 1 if it fails... instruct agent to run it, then create item on the script and instruct on how often to run it and at the end create trigger on the item ;-)
    ex: zabbix_server.conf (or something like this)
    UserParameter=pinghostB, /usr/sbin/ping <host B>
    then create item on pinghostB, etc.
    Bye
    • vinny
      • Jan 2008
      • 145
      thx for the reply,
      I thought about this solution but would hope secretly that a parameter would exist directly within the agent.
