Zabbix 1.6 auto discovery and Map
  • athreyavc
    • Aug 2007
    • 13
    Hi all,
    I am new to Zabbix. Sometime back I used it for testing and left it, now I am on it again.
    I have successfully installed version 1.6.4.
    I am trying to configure Auto Discovery.
    I have 3 hosts in the network. All in the range 192.168.10.1-20. I want zabbix to auto discover them using SNMP.
    I set up a rule called "snmprule" . I set Checks as SNMPv1 with community string as "public" (On the client the same community string been set and snmpd is running) and SNMPv2 with community string as "public"
    I see no device being detected from autodiscovery.
    Also the map only shows the "Zabbix Server" , except that it shows nothing.
    Please help me on this.
    Best Regards,
    Athreya VC
  • hbree
    • Jul 2009
    It would be great if some of the more advanced users would write (or point out) a howto on snmp discovery. I'm stuck with the same problem
    thanks in advance.
