Custom Dashboard's Last 20 issues?
  • markl
    • Apr 2008
    • 62
    Hi All,
    Not sure if this is possible, but I'd like to not view "non categorised" issues in the Last 20 issues on the dashboard. Anyone know if this is possible?
    The reason for this is that we would like to know when systems are running, not just problems, so at least we know that they are being monitored successfully. (otherwise we would always be assuming that everything is OK even though in reality, the systems may have stopped being monitored for whatever reason). I've put the systems running (i.e. everything is OK) into the non-categorised status, but they all show up as issues on the dashboard. We would like the Last 20 issues to only be actual issues and not just informational issues.
    Any help would be appreciated.
    Cheers,
    Mark.
  • markl
    • Apr 2008
    • 62
    Has anyone ever customised the dashboard or used a link from a 3rd party tool or in-house web development to customise the screen?
    Don't get me wrong, I like the dashboard, but I could do with "tweaking" it to make it better for what we want to use it for.
    Cheers
    • markl
      • Apr 2008
      • 62
      Has anyone ever done this? Is it possible to exclude a certain priority (not classified) from the 20 last issues on the dashboard?
      Thanks.
      • pesadilla
        • Nov 2006
        • 69
        it is not possible
        • Gunnar.Mann
          • Oct 2014
          Tweak for Zabbix 2.4
          I had the same problem and tweaked the php code (1Line). This is ugly and not upgrade-safe but simple:
          in Zabbix webroot (Ubuntu: /usr/share/zabbix) edit include/blocks.inc.php, Line 922:
          Insert filter option 'min_severity' => X, where X is the trigger severity (0-5, see Zabbix API documentation )
          PHP Code:
                  $triggers API::Trigger()->get(array_merge($options, array(
          'withLastEventUnacknowledged' => (isset($filter['extAck']) && $filter['extAck'] == EXTACK_OPTION_UNACK)
          true
          null,
          'skipDependent' => true,
          'output' => array('triggerid''state''error''url''expression''description''priority''lastchange'),
          'selectHosts' => array('hostid''name'),
          'selectLastEvent' => array('eventid''acknowledged''objectid''clock''ns'),
          'sortfield' => $sortField,
          'sortorder' => $sortOrder,
          'min_severity' => 1
          'limit' => isset($filter['limit']) ? $filter['limit'] : DEFAULT_LATEST_ISSUES_CNT
          After editing, reload your webserver and you're done.
          Last edited by Gunnar.Mann; 24-10-2014, 09:41. Reason: Added webserver reload comment
