monitor disk usage
  • ulises
    • Oct 2008
    • 13
    monitor disk usage
    Hi
    I have a question. I need to set up a hard drive monitor in some servers and I cant figure it out how to do it
    what I need is that we will get an alert if any partition is over 80% used
    how can I create a trigger like that?
    thanks in advance
  • simonuk1
    • Mar 2009
    • 66
    If you have a look at the triggers in the Template_Tomcat there are examples for 70% threshold.
    Hope that helps
    Simon
    • ulises
      • Oct 2008
      • 13
      thx for the reply; however, seems like the other admin deleted the tomcat template
      • tchjts1
        • May 2008
        • 1605
        Templates are here:
        http://www.zabbix.com/wiki/doku.php?...trib:templates
        • Kai-Kai
          • Apr 2009
          • 142
          If I right understand what you want to do, you have to :
          1. create an item to measure the free space in the partition :
          - description : Free disk space on $1 in %
          - type : agent ZABBIX
          - key : vfs.fs.size[/partition,pfree] (change /partition to the mount point)
          - infos type : Numérique (float)
          You can customize others fields...
          2. create a trigger to make an alert...
          - name : Low free disk space on {HOSTNAME} volume /partition
          - expression : {the_name_of_the_host:vfs.fs.size[/partition,pfree].last(0)}<20
          Customize the reste of the options (dependencies etc)...
          Now, you have an alert if the free space on /partition is less than 20% (so if the partition is 80% full).
          Is it ok for you ?
          • Calimero
            • Nov 2006
            • 481
            3. Create an action (we use a single generic Action for all triggers here) if you wan't zabbix_server to act when trigger is ON: send notifications, run commands ...
            • Kai-Kai
              • Apr 2009
              • 142
              He just asked to create an alert... ^^ that's why I haven't mentionned actions creation, but you're right, it's possible to define automated actions such as mail or remote command...
              • MrKen
                • Oct 2008
                • 652
                Originally posted by fcge
                Now, you have an alert ...
                No you don't! Now you have a Trigger.
                Calimero is correct. If you want an alert, you must create an action based on the trigger.
                MrKen
                • sbarnett
                  • Mar 2009
                  • 35
                  Try this also
                  • Kai-Kai
                    • Apr 2009
                    • 142
                    It depends of what you call alert...
                    According to me : alert = displaying on the dashboard. A trigger is the test, the trigger can be on "problem" or on "ok". When the trigger is on "problem", it's displayed on the dashboard : it's an alert.
                    So, you have an alert...
                    Sending email is an action following the alert.
                    So, I don't agree with you, but It's a question of point of view.
                    But what is sure is that ulises should find what he was loocking for, in this thread.
                    • MrKen
                      • Oct 2008
                      • 652
                      And, I don't agree with you!
                      Cheers, have a good day.
                      • ulises
                        • Oct 2008
                        • 13
                        thank you guys for all your replies... it help me alot to understand zabbix
                        however; I still cant get it to work
                        I added some items and triggers to an existing template but i got many false positives
                        the trigger i used was
                        {Template_test1:vfs.fs.size[/home,used]. last( 0 ) }>80
                        which should only generate the alert when /home has used 80% of the space right?
                        well, that did not work; I got many alerts from this trigger even though /home was using less than 50%
                        then, I changed the trigger to
                        {Template_test1:vfs.fs.size[/home,free]. last( 0 ) }<63
                        which should generate the template if /home has used over 37% right?
                        well, i got some OK alerts but not PROBLEM -- and i made sure 2 servers were using 40% of /home space
                        so i'm lost again
                        any help would be really appreciated
                        thx again
                        • MrKen
                          • Oct 2008
                          • 652
                          If you want a trigger for %, you need to use 'pfree' (percentage free) and 'pused' (percentage used).
                          e.g {Template_test1:vfs.fs.size[/home,pused]. last( 0 ) }>80
                          MrKen
                          • Kai-Kai
                            • Apr 2009
                            • 142
                            If we were always the same opinion, it would become boring.
                            Have a nice day too MrKen.
                            so i'm lost again
                            As MrKen said, you have to be carefull. There's a difference between "used" and "pused". The first one gives you the value in bytes (if I well remember - if you put B in the 5th field and custom multiplication by 1024). The second one gives you the values in percentage (pfree, pused).
                            If you see my example on the first page, I used pfree.
                            So in this case, you have to make an item using pfree, and then the associated trigger should work better.
                            • ulises
                              • Oct 2008
                              • 13
                              #15
                              oh ok thx guys; however, when i go to create a new ITEM it does not show the key i need to use (pfree nor puse)... anyway to get it again?
