Scheduling
  • Emma
    • Aug 2005
    Scheduling
    I have tried searching around for an answer to my question to no end. I am trying to alter the times on when a particular check runs. For example I am only on call for certain servers Monday to Friday and only want the system to check on these days and alert.
    I can re-design my alert scripts but was hoping Zabbix has a way to schedule these things.
    Cheers
  • James Wells
    • Jun 2005
    • 664
    Greetings,
    At present, Zabbix doesn't provide a mechanism for scheduling checks the way you want it to, it does however, have a mechanism for scheduling alert notifications. Under the media types per user, you will see something like;
    1-7,00:00-23:59
    What this is saying is to alert on any day between 1 and 7 and any time between midnight and 11:59PM, in your case, I believe you would want to change this to;
    2-6,00:00-23:59
    There has been talk on these forums recently about regarding adding an actual scheduling mechanism for checks, but I am not sure where that stands at present or if it will be a feature in the 1.1 release.
    Unofficial Zabbix Developer
    • Emma
      • Aug 2005
      Thanks James that will work for me, cheers
      • Nate Bell
        • Feb 2005
        • 141
        I think the time format goes like this:
        1 = Monday -> 7 = Sunday, so if he only wants alerts Monday-Friday, that should look like:
        1-5,00:00-23:59
        If not, then I have some settings I need to change.
        Just a side note, you can string multiple times together with a ;
        Lets say you want to be alerted only at night, but not during working hours (lets say from 8am - 5pm). You could do it like so:
        1-5,00:00-07:59;1-5,17:00,23:59,1-7,00:00-23:59
        Boom, skips over the working hours, alerts you at night, and on the weekends. Sort of the inverse of what you were looking for, but you get the idea.
        Nate
        • rajeevtomar
          • Mar 2005
          • 50
          I am wondering if this is possible in zabbix 1.0 .
          James and Nate, please let me know, if I can also work on this line for 1.0 version.
          Regards, Rajeev
          • Nate Bell
            • Feb 2005
            • 141
            Sorry. It's a 1.1 only feature. However, if you want to set a trigger to only trigger at a certain time of day, there is a way. Ripped straight from the manual:
            Function | Definition
            time()   | Returns current time in HHMMSS format. Example: 123055
            Example: CPU activity at night time
            Use of function time():
            [COLOR=Sienna]({zabbix:system[procload].nodata(180)}=1)&({zabbix:system[procload].time(0)}>000000)& ({zabbix:system[procload].time(0)}<060000)[/COLOR]
            The trigger may change its status to true, only at night (00:00-06:00) time.
            Unfortunately, there isn't a way that I know of to set which days this this happens on.
            Nate
