Using Zabbix 1.1 alpha 12 I am getting the following on my Windows 2000 server at a remote site over a 256k link.
[26-Aug-2005 10:01:53] Log file opened
[26-Aug-2005 10:01:53] Collector thread initialized successfully
[26-Aug-2005 10:01:53] Zabbix Win32 Agent started
[26-Aug-2005 10:02:04] Processing took more then 100 milliseconds (375 milliseconds)
[26-Aug-2005 10:02:16] Active checks [Cannot connect to [10.62.9.21:10051] [No error]]
[26-Aug-2005 10:03:39] Active checks [Cannot connect to [10.62.9.21:10051] [No error]]
[26-Aug-2005 10:05:01] Active checks [Cannot connect to [10.62.9.21:10051] [No error]]
[26-Aug-2005 10:05:06] Processing took more then 100 milliseconds (8391 milliseconds)
[26-Aug-2005 10:06:06] Processing took more then 100 milliseconds (9171 milliseconds)
[26-Aug-2005 10:06:07] Processing took more then 100 milliseconds (610 milliseconds)
[26-Aug-2005 10:06:18] Processing took more then 100 milliseconds (797 milliseconds)
[26-Aug-2005 10:06:24] Active checks [Cannot connect to [10.62.9.21:10051] [No error]]
[26-Aug-2005 10:06:40] Processing took more then 100 milliseconds (2125 milliseconds)
[26-Aug-2005 10:07:47] Active checks [Cannot connect to [10.62.9.21:10051] [No error]]
[26-Aug-2005 10:09:10] Active checks [Cannot connect to [10.62.9.21:10051] [No error]]
[26-Aug-2005 10:10:18] Processing took more then 100 milliseconds (547 milliseconds)
[26-Aug-2005 10:10:33] Active checks [Cannot connect to [10.62.9.21:10051] [No error]]
As you can see I am using Active Checks (I hoped they would prevent this timeout issue), but even if I set the zabbix_agentd.conf 'Timeout' value to 10 seconds items still timeout.
There is no firewall between my local Zabbix Server and remote host.
Can anyone suggest anything I could try to resolve this issue.
Thanks,
Dan
Thanks,
Dan
