items:
1.
type: Simple Check
key: icmpping
2.
type: SNMPv1 Agent
a TRIGGER assigned for ITEM 1 is:
{host:icmpping.last(0)}=0
so, when ITEM1 is "Active" and ITEM2 is "Not Active" TRIGGER works fine,
but if ITEM2 is activated TRIGGER goes UNKNOWN and host status on the network map becomes OK.
1.
type: Simple Check
key: icmpping
2.
type: SNMPv1 Agent
