Is there a way to display '1 second intervals' on graphs?
We're trying to do a 'realtime monitoring' sort of thing on switches/routers interfaces, and we would need to add 1 second intervals to the graphs.
We won't have this item enabled (Active) all the time, we'll only enable it when trying to identify problems on the network.
I was told that What's Up Gold has a similar feature...
Any ideas on how to do that? or any suggestions? Maybe how to zoom in a bit more on the graphs? As you can see in the screenshot attached, I'm polling an item via snmp every second, but the graph only shows 2 minute intervals.
Cheers,
Fernando
Cheers,
Fernando
