Hi all,
I am having a problem with some actions not working. I have some items/triggers set up using snmp for memory usage cpu and disk space on windows servers. It is using the external check. Now I also have items/triggers set using the Zabbix agent for the same things. I do not get any actions from the external checks but I do from the zabbix agent. I see in the dashboard memory usage high >80% but no action triggered a e-mail for the external check, but it does using the zabbix agent. Any suggestions?
