Howto use item as trigger function argument
  • jcesario
    • Apr 2009
    • 65
    I would like to do something like this. However zabbix keeps throwing a syntax error at me
    {Template_MySQL50_Repl:mysql50.repl[Relay_Log_Pos].last(0)}>65536 & {Template_MySQL50_Repl:mysql50.repl[Master_Log_File].str({Template_MySQL50_Repl:mysql50.repl[Relay_Master_Log_File].last(0)})}=0
    * Incorrect trigger expression. [ ... & {Template_MySQL50_Repl:mysql50.repl[Master_Log_File].str( ... ]
  • jcesario
    • Apr 2009
    • 65
    bump? Could use some help with this.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      It is not supported.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • jcesario
        • Apr 2009
        • 65
        Seriously 0.o ? That seems like such a common thing to do. Compare two dynamic strings against each other...
        • RoyK
          • Jan 2016
          • 22
          Any idea when it may be supported? I'm using this to look for servers that will die soon because of full memory timeleft(//vm.memory.size[available],3d,0) - which is fine - mostly. But I want to do it for all the server's uptime, perhaps minus 10 minutes for bootup and stabilisation, like timeleft(//vm.memory.size[available],system.uptime-10m,0). However, I can't find a way to do that. How can I?
