zabbix with dynamic ip (agentd)
  • axel
    • Aug 2005
    • 36
    Hi
    I have a new zabbix @ a local network with a dynamic IP.
    How can i configure the agents @ the clients.
    i have to set the zabbix server @ each client .
    for example:
    server="zabbix server ip"
    But i have a dynamic zabbix Server ip.
    Anyone can help me to fix the Problem ?
  • Alex Rabotiajev
    • Aug 2005
    Originally posted by axel
    Hi
    for example:
    You mast use computer name from dns. Not ip addres.
    • axel
      • Aug 2005
      • 36
      But if i set.
      Server=host.dyndns.org
      the zabbix_agentd.log say me .
      Connection from [xx.xx.193.201] rejected. Allowed server is [host.dynalias.org]
      What can i do ?
      • James Wells
        • Jun 2005
        • 664
        Greetings,
        I actually just reposted Simon Matter's patch for this last night. The patch is in the thread called;
        PATCH: Allow use of server Hostname or IP in agent config
        Unofficial Zabbix Developer
        • axel
          • Aug 2005
          • 36
          hi again
          ok i edit my security.c with the changes.
          Than i recompile it with ./configure --enable-agent --prefix=/..../...
          now i start the new agentd again but i have the same Problem
          do i miss something ?
          • James Wells
            • Jun 2005
            • 664
            Grrrr. I guess I misunderstood your original message. What you are dealing with is different from the intent of the patch. The patch supports server naming, however, it uses DNS to look up the hostname of the servrer connecting to it. Unfortunately, dynalias.org does not update the DNS PTR records, which is what the agent has to use as it is looking up the host name from the server IP.
            In your case, you will have to use the Zabbix agent in active mode.
            • axel
              • Aug 2005
              • 36
              ok thx i try it
              • James Wells
                • Jun 2005
                • 664
                Good luck. And sorry for the misunderstanding.
                • ruckus37
                  • Oct 2004
                  • 57
                  Just for interest are you also monitoring client pc's
                  • James Wells
                    • Jun 2005
                    • 664
                    Was just thinking about this a bit more. and I think I see HUGE problem.
                    On startup, the agent reads the config file to obtain the server's IP address, or if you use the patch, the servers IP address or hostname which it translates into an IP address. The agent will continue to use that IP address, and that IP address only until it is restarted. Now, depending on how often you recieve a new IP address, this could cause you to completely lose contact with the agents, and even more importantly, open the agents up to possible compromise.
                    For example. You recieve a DHCP assigned IP address, you remote over and start the agent. The agent gets the IP address and starts communicating with the server. 15 minutes later, you get a new DHCP IP addressfor whatever reason. You will have to restart the agent or competely lose access to it. However, agent, is still sending data to the old IP address and if someone just happens to have a Zabbix server running at that old IP address, they now have full access to the Zabbix agent.
                    • axel
                      • Aug 2005
                      • 36
                      i find out another way but not stable way . (only for testing)
                      I write a script that if the firewall @ the local network get a new ip the firewall connect to a monitored server and edit the zabbix_agentd.cfg and restart agent.
                      But tomorrow i try the aktive checks i hope that everything i need is supported
                      • hwinkel
                        • Sep 2005
                        Why not sending data to the Server
                        We also thinking of using Zabbix for many remote devices connected with
                        DSL lines with Dynamic IP's.
                        Can the agentd send performance data to the server ?
