device limit on dashboard ?
  • wpervaiz
    • May 2009
    • 30
    hey guys, i'm using the zabbix system in a different way; when a device is down, it shows up under "high", "average", or "warning" on the dashboard.
    If a device is up however, it shows up under "information" - the problem now is that there seems to be a limit to how many devices can show up in "information" - i can add as many devices to a template, but i cant display more than 30 devices in each row on the dashboard.
    any ideas ?
  • wpervaiz
    • May 2009
    • 30
    bump, anyone ?
    • Aly
      ZABBIX developer
      • May 2007
      • 1126
      It's a hardcoded limit, you may manually remove it by editing blocks.inc.php line ~281:
      PHP Code:
      // if($tr_count > 30) continue;
      Zabbix | ex GUI developer
      • wpervaiz
        • May 2009
        • 30
        awesome ! thanks!
        was there any particular reason this limit was set other than performance/speed issues ?
        • Aly
          ZABBIX developer
          • May 2007
          • 1126
          Usability and page load.
