system.cpu.util on solaris
  • tdomhan
    • Jul 2009
    • 24
    hi folks,
    I have a Solaris 10 machine here which I would like to monitor.
    I'm especially interessed in the CPU usage. I added an item system.cpu.util, which works. It should show the cpu usage in percent shouldn't it?
    well it shows something between 70-90% cpu usage.
    though mpstat says something like this:
    CPU minf mjf xcal  intr ithr  csw icsw migr smtx  srw syscl  usr sys  wt idl
      0    1   0    0   287   91  153    3    0    7    0  1077    5   1   0  94
    so the machine idles 94% of the time, doesn't it?
    and in prstat the only process consuming cpu is mysql with around 5%.
    can somebody explain me that divergence?
    edit: I'm using the newest 1.6 sources for both agent and server.
  • tdomhan
    • Jul 2009
    • 24
    ok strange thing, if I do something CPU heavy the graph drops to the ground, what would be around 1%....
    If I explicitly change the type to user the values seem fine.
    is this a bug, or indented as the manual says "user" is the default?
